Cesium for Unreal 2.31.0
#include <CesiumSubLevel.h>
| FString | LevelName |
| The plain name of the sub level, without any prefixes. | |
| bool | Enabled = true |
| Whether this sub-level is enabled. | |
| double | LevelLatitude = 0.0 |
| The WGS84 latitude in degrees of where this level should sit on the globe, in the range [-90, 90]. | |
| double | LevelLongitude = 0.0 |
| The WGS84 longitude in degrees of where this level should sit on the globe, in the range [-180, 180]. | |
| double | LevelHeight = 0.0 |
| The height in meters above the WGS84 globe this level should sit. | |
| double | LoadRadius = 0.0 |
| How far in meters from the sublevel local origin the camera needs to be to load the level. | |
| bool | CanBeEnabled = false |
Definition at line 20 of file CesiumSubLevel.h.
| bool FCesiumSubLevel::CanBeEnabled = false |
Definition at line 86 of file CesiumSubLevel.h.
| bool FCesiumSubLevel::Enabled = true |
An enabled sub-level will be automatically loaded when the camera moves within its LoadRadius and no other levels are closer, and the Georeference will be updated so that this level's Longitude, Latitude, and Height bcome (0, 0, 0) in the Unreal World. A sub-level that is not enabled will be ignored by Cesium.
If this option is greyed out, check that World Composition is enabled in the World Settings and that this sub-level is in a Layer that has Distance-based streaming DISABLED.
Definition at line 44 of file CesiumSubLevel.h.
| double FCesiumSubLevel::LevelHeight = 0.0 |
Definition at line 73 of file CesiumSubLevel.h.
| double FCesiumSubLevel::LevelLatitude = 0.0 |
Definition at line 54 of file CesiumSubLevel.h.
| double FCesiumSubLevel::LevelLongitude = 0.0 |
Definition at line 64 of file CesiumSubLevel.h.
| FString FCesiumSubLevel::LevelName |
Definition at line 27 of file CesiumSubLevel.h.
| double FCesiumSubLevel::LoadRadius = 0.0 |
Definition at line 83 of file CesiumSubLevel.h.
