CesiumTilesetJson::Subtrees Struct Referencefinal
An object describing the location of subtree files. More...
#include <CesiumTilesetJson/Subtrees.h>
Inheritance diagram for CesiumTilesetJson::Subtrees:
std::string uri
 A URI with embedded expressions that describes the resource that is associated with an implicit tile in an implicit tileset. Allowed expressions are {level}, {x}, {y}, and {z}. {level} is substituted with the level of the node, {x} is substituted with the x index of the node within the level, and {y} is substituted with the y index of the node within the level. {z} may only be given when the subdivision scheme is OCTREE, and it is substituted with the z index of the node within the level.
static constexpr const char * TypeName = "Subtrees"
Definition at line 14 of file Subtrees.h.
int64_t CesiumTilesetJson::Subtrees::getSizeBytes ( ) const
Definition at line 32 of file Subtrees.h.
const char* CesiumTilesetJson::Subtrees::TypeName = "Subtrees"
Definition at line 19 of file Subtrees.h.
◆ uri
std::string CesiumTilesetJson::Subtrees::uri
Definition at line 24 of file Subtrees.h.
