cesium-native 0.67.0
Defines the structure of a single content item in 3DTILES_content_conditional. More...
#include <CesiumTilesetJson/ConditionalContentItem.h>
Public Member Functions inherited from CesiumTilesetJson::Content | |
| std::unordered_map< std::string, CesiumUtility::JsonValue > | keys |
| Properties that define the conditions based on which the item can become active. The names of these properties correspond to the 'dimensions' that are defined in the top-level extension object. | |
Public Attributes inherited from CesiumTilesetJson::Content | |
| std::optional< CesiumTilesetJson::BoundingVolume > | boundingVolume |
| An optional bounding volume that tightly encloses tile content. tile.boundingVolume provides spatial coherence and tile.content.boundingVolume enables tight view frustum culling. When this is omitted, tile.boundingVolume is used. | |
| std::string | uri |
| A uri that points to tile content. When the uri is relative, it is relative to the referring tileset JSON file. | |
| std::optional< CesiumTilesetJson::MetadataEntity > | metadata |
| Metadata that is associated with this content. | |
| std::optional< int64_t > | group |
The group this content belongs to. The value is an index into the array of groups that is defined for the containing tileset. | |
| static constexpr const char * | TypeName = "ConditionalContentItem" |
Static Public Attributes inherited from CesiumTilesetJson::Content | |
| static constexpr const char * | TypeName = "Content" |
Definition at line 17 of file ConditionalContentItem.h.
Definition at line 36 of file ConditionalContentItem.h.
| std::unordered_map<std::string, CesiumUtility::JsonValue> CesiumTilesetJson::ConditionalContentItem::keys |
Definition at line 28 of file ConditionalContentItem.h.
Definition at line 21 of file ConditionalContentItem.h.
