CesiumGltf::Statistics Struct Referencefinal
Statistics about entities. More...
#include <CesiumGltf/Statistics.h>
Inheritance diagram for CesiumGltf::Statistics:
std::unordered_map< std::string, CesiumGltf::ClassStatistics > classes
 A dictionary, where each key corresponds to a class ID in the classes dictionary of the metatata schema that was defined for the asset that contains these statistics. Each value is an object containing statistics about entities that conform to the class.
static constexpr const char * TypeName = "Statistics"
Definition at line 16 of file Statistics.h.
int64_t CesiumGltf::Statistics::getSizeBytes ( ) const
Definition at line 37 of file Statistics.h.
◆ classes
std::unordered_map<std::string, CesiumGltf::ClassStatistics> CesiumGltf::Statistics::classes
Definition at line 29 of file Statistics.h.
const char* CesiumGltf::Statistics::TypeName = "Statistics"
Definition at line 21 of file Statistics.h.
