CesiumGltf::ClassStatistics Struct Referencefinal
Statistics about entities that conform to a class that was defined in a metadata schema. More...
#include <CesiumGltf/ClassStatistics.h>
Inheritance diagram for CesiumGltf::ClassStatistics:
std::optional< int64_t > count
 The number of entities that conform to the class.
std::unordered_map< std::string, CesiumGltf::PropertyStatistics > properties
 A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value is an object containing statistics about property values.
static constexpr const char * TypeName = "ClassStatistics"
Definition at line 19 of file ClassStatistics.h.
int64_t CesiumGltf::ClassStatistics::getSizeBytes ( ) const
Definition at line 44 of file ClassStatistics.h.
◆ count
std::optional<int64_t> CesiumGltf::ClassStatistics::count
Definition at line 29 of file ClassStatistics.h.
◆ properties
std::unordered_map<std::string, CesiumGltf::PropertyStatistics> CesiumGltf::ClassStatistics::properties
Definition at line 36 of file ClassStatistics.h.
const char* CesiumGltf::ClassStatistics::TypeName = "ClassStatistics"
Definition at line 24 of file ClassStatistics.h.
