PropertyAttributeProperty.h
9#include <optional>
10#include <string>
11
12namespace CesiumGltf {
16struct CESIUMGLTF_API PropertyAttributeProperty final
21 static constexpr const char* TypeName = "PropertyAttributeProperty";
22
26 std::string attribute;
27
33 std::optional<CesiumUtility::JsonValue> offset;
34
40 std::optional<CesiumUtility::JsonValue> scale;
41
48 std::optional<CesiumUtility::JsonValue> max;
49
56 std::optional<CesiumUtility::JsonValue> min;
57
64 int64_t getSizeBytes() const {
65 int64_t accum = 0;
66 accum += int64_t(sizeof(PropertyAttributeProperty));
68 int64_t(sizeof(CesiumUtility::ExtensibleObject));
69 accum += int64_t(this->attribute.capacity() * sizeof(char));
70 return accum;
71 }
72};
73} // namespace CesiumGltf
An attribute containing property values.
The name of the attribute containing property values.
Maximum value present in the property values. Only applicable to SCALAR, VECN, and MATN types....
Minimum value present in the property values. Only applicable to SCALAR, VECN, and MATN types....
An offset to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64,...
A scale to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64,...
