CesiumGltf::Light Struct Referencefinal
A directional, point, or spot light. More...
#include <CesiumGltf/Light.h>
Inheritance diagram for CesiumGltf::Light:
Classes
struct  Type
 Known values for Specifies the light type. More...
std::vector< double > color = {1, 1, 1}
 Color of the light source.
double intensity = 1
 Intensity of the light source. point and spot lights use luminous intensity in candela (lm/sr) while directional lights use illuminance in lux (lm/m^2)
std::optional< CesiumGltf::Spotlight > spot
 spot
std::string type = Type::directional
std::optional< double > range
 A distance cutoff at which the light's intensity may be considered to have reached zero.
std::string name
static constexpr const char * TypeName = "Light"
Definition at line 17 of file Light.h.
int64_t CesiumGltf::Light::getSizeBytes ( ) const
Definition at line 95 of file Light.h.
◆ color
std::vector<double> CesiumGltf::Light::color = {1, 1, 1}
Definition at line 61 of file Light.h.
◆ intensity
double CesiumGltf::Light::intensity = 1
Definition at line 68 of file Light.h.
◆ range
std::optional<double> CesiumGltf::Light::range
Definition at line 87 of file Light.h.
◆ spot
std::optional<CesiumGltf::Spotlight> CesiumGltf::Light::spot
spot
Definition at line 73 of file Light.h.
◆ type
std::string CesiumGltf::Light::type = Type::directional
Definition at line 81 of file Light.h.
const char* CesiumGltf::Light::TypeName = "Light"
Definition at line 21 of file Light.h.
