CesiumGltf::Layer Struct Referencefinal
An object defining a layer. More...
#include <CesiumGltf/Layer.h>
Inheritance diagram for CesiumGltf::Layer:
static constexpr const char * TypeName = "Layer"
Additional Inherited Members
std::string name
Definition at line 12 of file Layer.h.
int64_t CesiumGltf::Layer::getSizeBytes ( ) const
Definition at line 24 of file Layer.h.
const char* CesiumGltf::Layer::TypeName = "Layer"
Definition at line 16 of file Layer.h.
