CesiumGltf::FeatureId Struct Referencefinal
Feature IDs stored in an attribute or texture. More...
#include <CesiumGltf/FeatureId.h>
Inheritance diagram for CesiumGltf::FeatureId:
int64_t featureCount = int64_t()
 The number of unique features in the attribute or texture.
std::optional< int64_t > nullFeatureId
 A value that indicates that no feature is associated with this vertex or texel.
std::optional< std::string > label
 A label assigned to this feature ID set. Labels must be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
std::optional< int64_t > attribute
 An integer value used to construct a string in the format _FEATURE_ID_<set index> which is a reference to a key in mesh.primitives.attributes (e.g. a value of 0 corresponds to _FEATURE_ID_0).
std::optional< CesiumGltf::FeatureIdTexture > texture
 A texture containing feature IDs.
int32_t propertyTable = -1
 The index of the property table containing per-feature property values. Only applicable when using the EXT_structural_metadata extension.
static constexpr const char * TypeName = "FeatureId"
Definition at line 17 of file FeatureId.h.
int64_t CesiumGltf::FeatureId::getSizeBytes ( ) const
Definition at line 65 of file FeatureId.h.
◆ attribute
std::optional<int64_t> CesiumGltf::FeatureId::attribute
Definition at line 46 of file FeatureId.h.
◆ featureCount
int64_t CesiumGltf::FeatureId::featureCount = int64_t()
Definition at line 26 of file FeatureId.h.
◆ label
std::optional<std::string> CesiumGltf::FeatureId::label
Definition at line 38 of file FeatureId.h.
◆ nullFeatureId
std::optional<int64_t> CesiumGltf::FeatureId::nullFeatureId
Definition at line 32 of file FeatureId.h.
◆ propertyTable
int32_t CesiumGltf::FeatureId::propertyTable = -1
Definition at line 57 of file FeatureId.h.
◆ texture
std::optional<CesiumGltf::FeatureIdTexture> CesiumGltf::FeatureId::texture
Definition at line 51 of file FeatureId.h.
const char* CesiumGltf::FeatureId::TypeName = "FeatureId"
Definition at line 21 of file FeatureId.h.
