CesiumGltf::ExternalAsset Struct Referencefinal
An external asset that references a file in the files array and may be instantiated by any node. More...
#include <CesiumGltf/ExternalAsset.h>
Inheritance diagram for CesiumGltf::ExternalAsset:
int32_t file = -1
 The index of the file reference used for this external asset.
std::string name
static constexpr const char * TypeName = "ExternalAsset"
Definition at line 15 of file ExternalAsset.h.
int64_t CesiumGltf::ExternalAsset::getSizeBytes ( ) const
Definition at line 35 of file ExternalAsset.h.
◆ file
int32_t CesiumGltf::ExternalAsset::file = -1
The index of the file reference in the top-level files array used for this external asset.
Definition at line 27 of file ExternalAsset.h.
const char* CesiumGltf::ExternalAsset::TypeName = "ExternalAsset"
Definition at line 19 of file ExternalAsset.h.
