CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue Struct Referencefinal
ExtensionNodeMaxarMeshVariants Mappings Value. More...
#include <CesiumGltf/ExtensionNodeMaxarMeshVariantsMappingsValue.h>
Inheritance diagram for CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue:
std::vector< int32_t > variants
 An array of variant index values.
int32_t mesh = -1
 The mesh associated with the set of variants.
 The user-defined name of this variant mesh mapping.
int64_t CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue::getSizeBytes ( ) const
Definition at line 46 of file ExtensionNodeMaxarMeshVariantsMappingsValue.h.
◆ mesh
int32_t CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue::mesh = -1
Definition at line 33 of file ExtensionNodeMaxarMeshVariantsMappingsValue.h.
◆ name
std::optional<std::string> CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue::name
Definition at line 38 of file ExtensionNodeMaxarMeshVariantsMappingsValue.h.
const char* CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue::TypeName
Initial value:
"ExtensionNodeMaxarMeshVariantsMappingsValue"
Definition at line 22 of file ExtensionNodeMaxarMeshVariantsMappingsValue.h.
◆ variants
std::vector<int32_t> CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue::variants
Definition at line 28 of file ExtensionNodeMaxarMeshVariantsMappingsValue.h.
