CesiumGltf::ExtensionNodeMaxarMeshVariants Struct Referencefinal
MAXAR_mesh_variants node extension. More...
#include <CesiumGltf/ExtensionNodeMaxarMeshVariants.h>
Inheritance diagram for CesiumGltf::ExtensionNodeMaxarMeshVariants:
std::vector< CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue > mappings
 A list of mesh to variant mappings.
static constexpr const char * TypeName = "ExtensionNodeMaxarMeshVariants"
static constexpr const char * ExtensionName = "MAXAR_mesh_variants"
Definition at line 15 of file ExtensionNodeMaxarMeshVariants.h.
int64_t CesiumGltf::ExtensionNodeMaxarMeshVariants::getSizeBytes ( ) const
Definition at line 36 of file ExtensionNodeMaxarMeshVariants.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionNodeMaxarMeshVariants::ExtensionName = "MAXAR_mesh_variants"
Definition at line 23 of file ExtensionNodeMaxarMeshVariants.h.
◆ mappings
std::vector<CesiumGltf::ExtensionNodeMaxarMeshVariantsMappingsValue> CesiumGltf::ExtensionNodeMaxarMeshVariants::mappings
Definition at line 28 of file ExtensionNodeMaxarMeshVariants.h.
const char* CesiumGltf::ExtensionNodeMaxarMeshVariants::TypeName = "ExtensionNodeMaxarMeshVariants"
Definition at line 20 of file ExtensionNodeMaxarMeshVariants.h.
