KHR_lights_punctual glTF Node Extension. More...
#include <CesiumGltf/ExtensionNodeKhrLightsPunctual.h>
| int32_t | light = -1 |
| The id of the light referenced by this node. | |
| static constexpr const char * | TypeName = "ExtensionNodeKhrLightsPunctual" |
| static constexpr const char * | ExtensionName = "KHR_lights_punctual" |
Definition at line 14 of file ExtensionNodeKhrLightsPunctual.h.
Definition at line 35 of file ExtensionNodeKhrLightsPunctual.h.
Definition at line 22 of file ExtensionNodeKhrLightsPunctual.h.
| int32_t CesiumGltf::ExtensionNodeKhrLightsPunctual::light = -1 |
Definition at line 27 of file ExtensionNodeKhrLightsPunctual.h.
Definition at line 19 of file ExtensionNodeKhrLightsPunctual.h.
