CesiumGltf::ExtensionNodeExtNodeVisibilityConditions Struct Referencefinal
Defines the structure of the extension object that is associated with a KHR_node_visibility object to define the conditions for the visibility. More...
#include <CesiumGltf/ExtensionNodeExtNodeVisibilityConditions.h>
Inheritance diagram for CesiumGltf::ExtensionNodeExtNodeVisibilityConditions:
std::unordered_map< std::string, CesiumUtility::JsonValue > conditions
 Properties that define the conditions based on which the 'visible' flag becomes 'true'. The names of these properties correspond to the 'dimensions' that are defined in the top-level extension object.
static constexpr const char * ExtensionName = "EXT_node_visibility_conditions"
Definition at line 17 of file ExtensionNodeExtNodeVisibilityConditions.h.
int64_t CesiumGltf::ExtensionNodeExtNodeVisibilityConditions::getSizeBytes ( ) const
Definition at line 41 of file ExtensionNodeExtNodeVisibilityConditions.h.
◆ conditions
std::unordered_map<std::string, CesiumUtility::JsonValue> CesiumGltf::ExtensionNodeExtNodeVisibilityConditions::conditions
Definition at line 33 of file ExtensionNodeExtNodeVisibilityConditions.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionNodeExtNodeVisibilityConditions::ExtensionName = "EXT_node_visibility_conditions"
Definition at line 26 of file ExtensionNodeExtNodeVisibilityConditions.h.
const char* CesiumGltf::ExtensionNodeExtNodeVisibilityConditions::TypeName
Initial value:
"ExtensionNodeExtNodeVisibilityConditions"
Definition at line 22 of file ExtensionNodeExtNodeVisibilityConditions.h.
