ExtensionNodeExtNodeVisibilityConditions.h
9#include <string>
10#include <unordered_map>
11
12namespace CesiumGltf {
22 static constexpr const char* TypeName =
23 "ExtensionNodeExtNodeVisibilityConditions";
26 static constexpr const char* ExtensionName = "EXT_node_visibility_conditions";
27
33 std::unordered_map<std::string, CesiumUtility::JsonValue> conditions;
34
41 int64_t getSizeBytes() const {
42 int64_t accum = 0;
43 accum += int64_t(sizeof(ExtensionNodeExtNodeVisibilityConditions));
45 int64_t(sizeof(CesiumUtility::ExtensibleObject));
46 accum += int64_t(
47 this->conditions.bucket_count() *
48 (sizeof(std::string) + sizeof(CesiumUtility::JsonValue)));
49 for (const auto& [k, v] : this->conditions) {
50 accum += int64_t(k.capacity() * sizeof(char) - sizeof(std::string));
51 accum += int64_t(sizeof(CesiumUtility::JsonValue));
52 }
53 return accum;
54 }
55};
56} // namespace CesiumGltf
Definition JsonValue.h:53
Defines the structure of the extension object that is associated with a KHR_node_visibility object to...
std::unordered_map< std::string, CesiumUtility::JsonValue > conditions
Properties that define the conditions based on which the 'visible' flag becomes 'true'....
