CesiumGltf::ExtensionModelMaxarMeshVariantsValue Struct Referencefinal
An object defining a valid mesh variant. More...
#include <CesiumGltf/ExtensionModelMaxarMeshVariantsValue.h>
Inheritance diagram for CesiumGltf::ExtensionModelMaxarMeshVariantsValue:
std::string name
 The name of the mesh variant.
std::string name
Definition at line 14 of file ExtensionModelMaxarMeshVariantsValue.h.
int64_t CesiumGltf::ExtensionModelMaxarMeshVariantsValue::getSizeBytes ( ) const
Definition at line 33 of file ExtensionModelMaxarMeshVariantsValue.h.
◆ name
std::string CesiumGltf::ExtensionModelMaxarMeshVariantsValue::name
Definition at line 25 of file ExtensionModelMaxarMeshVariantsValue.h.
const char* CesiumGltf::ExtensionModelMaxarMeshVariantsValue::TypeName
Initial value:
"ExtensionModelMaxarMeshVariantsValue"
Definition at line 19 of file ExtensionModelMaxarMeshVariantsValue.h.
