CesiumGltf::ExtensionModelMaxarMeshVariants Struct Referencefinal
glTF extension that defines mesh variants for nodes More...
#include <CesiumGltf/ExtensionModelMaxarMeshVariants.h>
Inheritance diagram for CesiumGltf::ExtensionModelMaxarMeshVariants:
int32_t defaultProperty = -1
 The index of the variant to load by default. The meshes that are mapped to the default variant must represent the set of meshes initially selected by the nodes for rendering, as per vanilla glTF behavior.
std::vector< CesiumGltf::ExtensionModelMaxarMeshVariantsValue > variants
 variants
static constexpr const char * TypeName = "ExtensionModelMaxarMeshVariants"
static constexpr const char * ExtensionName = "MAXAR_mesh_variants"
Definition at line 16 of file ExtensionModelMaxarMeshVariants.h.
int64_t CesiumGltf::ExtensionModelMaxarMeshVariants::getSizeBytes ( ) const
Definition at line 44 of file ExtensionModelMaxarMeshVariants.h.
◆ defaultProperty
int32_t CesiumGltf::ExtensionModelMaxarMeshVariants::defaultProperty = -1
Definition at line 31 of file ExtensionModelMaxarMeshVariants.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionModelMaxarMeshVariants::ExtensionName = "MAXAR_mesh_variants"
Definition at line 24 of file ExtensionModelMaxarMeshVariants.h.
const char* CesiumGltf::ExtensionModelMaxarMeshVariants::TypeName = "ExtensionModelMaxarMeshVariants"
Definition at line 21 of file ExtensionModelMaxarMeshVariants.h.
◆ variants
std::vector<CesiumGltf::ExtensionModelMaxarMeshVariantsValue> CesiumGltf::ExtensionModelMaxarMeshVariants::variants
variants
Definition at line 36 of file ExtensionModelMaxarMeshVariants.h.
