CesiumGltf::ExtensionModelKhrMaterialsVariantsValue Struct Referencefinal
An object defining a valid material variant. More...
#include <CesiumGltf/ExtensionModelKhrMaterialsVariantsValue.h>
Inheritance diagram for CesiumGltf::ExtensionModelKhrMaterialsVariantsValue:
std::string name
 The name of the material variant.
std::string name
Definition at line 14 of file ExtensionModelKhrMaterialsVariantsValue.h.
int64_t CesiumGltf::ExtensionModelKhrMaterialsVariantsValue::getSizeBytes ( ) const
Definition at line 33 of file ExtensionModelKhrMaterialsVariantsValue.h.
◆ name
std::string CesiumGltf::ExtensionModelKhrMaterialsVariantsValue::name
Definition at line 25 of file ExtensionModelKhrMaterialsVariantsValue.h.
const char* CesiumGltf::ExtensionModelKhrMaterialsVariantsValue::TypeName
Initial value:
"ExtensionModelKhrMaterialsVariantsValue"
Definition at line 19 of file ExtensionModelKhrMaterialsVariantsValue.h.
