ExtensionModelExtNodeVisibilityConditions Dimensions Value. More...
#include <CesiumGltf/ExtensionModelExtNodeVisibilityConditionsDimensionsValue.h>
| std::string | name |
| The name of the property that is used for defining the condition. | |
| std::vector< CesiumUtility::JsonValue > | domain |
| The set of all possible values for this dimension. | |
Definition at line 16 of file ExtensionModelExtNodeVisibilityConditionsDimensionsValue.h.
Definition at line 40 of file ExtensionModelExtNodeVisibilityConditionsDimensionsValue.h.
| std::vector<CesiumUtility::JsonValue> CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue::domain |
Definition at line 32 of file ExtensionModelExtNodeVisibilityConditionsDimensionsValue.h.
| std::string CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue::name |
Definition at line 27 of file ExtensionModelExtNodeVisibilityConditionsDimensionsValue.h.
Definition at line 21 of file ExtensionModelExtNodeVisibilityConditionsDimensionsValue.h.
