Defines the structure of the extension object that is stored as the EXT_node_visibility_conditions extension. More...
#include <CesiumGltf/ExtensionModelExtNodeVisibilityConditions.h>
| std::vector< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue > | dimensions |
| The dimensions of the conditions, each consisting of the name and domain of the respective property. | |
| static constexpr const char * | ExtensionName = "EXT_node_visibility_conditions" |
Definition at line 16 of file ExtensionModelExtNodeVisibilityConditions.h.
Definition at line 41 of file ExtensionModelExtNodeVisibilityConditions.h.
| std::vector< CesiumGltf::ExtensionModelExtNodeVisibilityConditionsDimensionsValue> CesiumGltf::ExtensionModelExtNodeVisibilityConditions::dimensions |
Definition at line 33 of file ExtensionModelExtNodeVisibilityConditions.h.
Definition at line 25 of file ExtensionModelExtNodeVisibilityConditions.h.
Definition at line 21 of file ExtensionModelExtNodeVisibilityConditions.h.
