CesiumGltf::ExtensionModel3dTilesLayers Struct Referencefinal
glTF extension that defines layers that nodes may belong to. More...
#include <CesiumGltf/ExtensionModel3dTilesLayers.h>
Inheritance diagram for CesiumGltf::ExtensionModel3dTilesLayers:
std::vector< CesiumGltf::Layer > layers
 An array of layers that nodes may belong to.
static constexpr const char * TypeName = "ExtensionModel3dTilesLayers"
static constexpr const char * ExtensionName = "3DTILES_layers"
Definition at line 15 of file ExtensionModel3dTilesLayers.h.
int64_t CesiumGltf::ExtensionModel3dTilesLayers::getSizeBytes ( ) const
Definition at line 36 of file ExtensionModel3dTilesLayers.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionModel3dTilesLayers::ExtensionName = "3DTILES_layers"
Definition at line 23 of file ExtensionModel3dTilesLayers.h.
◆ layers
std::vector<CesiumGltf::Layer> CesiumGltf::ExtensionModel3dTilesLayers::layers
Definition at line 28 of file ExtensionModel3dTilesLayers.h.
const char* CesiumGltf::ExtensionModel3dTilesLayers::TypeName = "ExtensionModel3dTilesLayers"
Definition at line 20 of file ExtensionModel3dTilesLayers.h.
