Structural metadata about a glTF primitive. More...
#include <CesiumGltf/ExtensionMeshPrimitiveExtStructuralMetadata.h>
| std::vector< int32_t > | propertyTextures |
An array of indexes of property textures in the root EXT_structural_metadata object. | |
| std::vector< int32_t > | propertyAttributes |
An array of indexes of property attributes in the root EXT_structural_metadata object. | |
| static constexpr const char * | ExtensionName = "EXT_structural_metadata" |
Definition at line 15 of file ExtensionMeshPrimitiveExtStructuralMetadata.h.
Definition at line 44 of file ExtensionMeshPrimitiveExtStructuralMetadata.h.
Definition at line 24 of file ExtensionMeshPrimitiveExtStructuralMetadata.h.
| std::vector<int32_t> CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata::propertyAttributes |
Definition at line 36 of file ExtensionMeshPrimitiveExtStructuralMetadata.h.
| std::vector<int32_t> CesiumGltf::ExtensionMeshPrimitiveExtStructuralMetadata::propertyTextures |
Definition at line 30 of file ExtensionMeshPrimitiveExtStructuralMetadata.h.
Definition at line 20 of file ExtensionMeshPrimitiveExtStructuralMetadata.h.
