ExtensionMeshPrimitiveExtStructuralMetadata.h
8#include <cstdint>
9#include <vector>
10
11namespace CesiumGltf {
20 static constexpr const char* TypeName =
21 "ExtensionMeshPrimitiveExtStructuralMetadata";
24 static constexpr const char* ExtensionName = "EXT_structural_metadata";
25
30 std::vector<int32_t> propertyTextures;
31
36 std::vector<int32_t> propertyAttributes;
37
44 int64_t getSizeBytes() const {
45 int64_t accum = 0;
46 accum += int64_t(sizeof(ExtensionMeshPrimitiveExtStructuralMetadata));
48 int64_t(sizeof(CesiumUtility::ExtensibleObject));
49 accum += int64_t(sizeof(int32_t) * this->propertyTextures.capacity());
50 accum += int64_t(sizeof(int32_t) * this->propertyAttributes.capacity());
51 return accum;
52 }
53};
54} // namespace CesiumGltf
std::vector< int32_t > propertyAttributes
An array of indexes of property attributes in the root EXT_structural_metadata object.
std::vector< int32_t > propertyTextures
An array of indexes of property textures in the root EXT_structural_metadata object.
