CesiumGltf::ExtensionKhrImplicitShapes Struct Referencefinal
Top level implicit shapes. More...
#include <CesiumGltf/ExtensionKhrImplicitShapes.h>
Inheritance diagram for CesiumGltf::ExtensionKhrImplicitShapes:
std::vector< CesiumGltf::ExtensionKhrImplicitShapesShape > shapes
 An array of shape descriptions.
static constexpr const char * TypeName = "ExtensionKhrImplicitShapes"
static constexpr const char * ExtensionName = "KHR_implicit_shapes"
Definition at line 15 of file ExtensionKhrImplicitShapes.h.
int64_t CesiumGltf::ExtensionKhrImplicitShapes::getSizeBytes ( ) const
Definition at line 36 of file ExtensionKhrImplicitShapes.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionKhrImplicitShapes::ExtensionName = "KHR_implicit_shapes"
Definition at line 23 of file ExtensionKhrImplicitShapes.h.
◆ shapes
std::vector<CesiumGltf::ExtensionKhrImplicitShapesShape> CesiumGltf::ExtensionKhrImplicitShapes::shapes
Definition at line 28 of file ExtensionKhrImplicitShapes.h.
const char* CesiumGltf::ExtensionKhrImplicitShapes::TypeName = "ExtensionKhrImplicitShapes"
Definition at line 20 of file ExtensionKhrImplicitShapes.h.
