Data defining a 3D Gaussian Splat primitive. More...
#include <CesiumGltf/ExtensionKhrGaussianSplatting.h>
Classes | |
| struct | ColorSpace |
| Known values for The color space of the reconstructed color values. More... | |
| struct | Kernel |
| Known values for The kernel used to generate the Gaussians. More... | |
| struct | Projection |
| Known values for The projection method for rendering the Gaussians. More... | |
| struct | SortingMethod |
| Known values for The sorting method for rendering the Gaussians. More... | |
| std::string | kernel = Kernel::ellipse |
| The kernel used to generate the Gaussians. | |
| std::string | colorSpace = ColorSpace::srgb_rec709_display |
| The color space of the reconstructed color values. | |
| std::string | projection = Projection::perspective |
| The projection method for rendering the Gaussians. | |
| std::string | sortingMethod = SortingMethod::cameraDistance |
| The sorting method for rendering the Gaussians. | |
| static constexpr const char * | TypeName = "ExtensionKhrGaussianSplatting" |
| static constexpr const char * | ExtensionName = "KHR_gaussian_splatting" |
Definition at line 14 of file ExtensionKhrGaussianSplatting.h.
Definition at line 97 of file ExtensionKhrGaussianSplatting.h.
| std::string CesiumGltf::ExtensionKhrGaussianSplatting::colorSpace = ColorSpace::srgb_rec709_display |
Known values are defined in ColorSpace.
Definition at line 73 of file ExtensionKhrGaussianSplatting.h.
Definition at line 22 of file ExtensionKhrGaussianSplatting.h.
| std::string CesiumGltf::ExtensionKhrGaussianSplatting::kernel = Kernel::ellipse |
Known values are defined in Kernel.
Definition at line 65 of file ExtensionKhrGaussianSplatting.h.
| std::string CesiumGltf::ExtensionKhrGaussianSplatting::projection = Projection::perspective |
Known values are defined in Projection.
Definition at line 81 of file ExtensionKhrGaussianSplatting.h.
| std::string CesiumGltf::ExtensionKhrGaussianSplatting::sortingMethod = SortingMethod::cameraDistance |
Known values are defined in SortingMethod.
Definition at line 89 of file ExtensionKhrGaussianSplatting.h.
Definition at line 19 of file ExtensionKhrGaussianSplatting.h.
