ExtensionKhrGaussianSplatting.h
8#include <string>
9
10namespace CesiumGltf {
14struct CESIUMGLTF_API ExtensionKhrGaussianSplatting final
19 static constexpr const char* TypeName = "ExtensionKhrGaussianSplatting";
22 static constexpr const char* ExtensionName = "KHR_gaussian_splatting";
23
27 struct Kernel {
29 inline static const std::string ellipse = "ellipse";
30 };
31
35 struct ColorSpace {
37 inline static const std::string srgb_rec709_display = "srgb_rec709_display";
38
40 inline static const std::string lin_rec709_display = "lin_rec709_display";
41 };
42
46 struct Projection {
48 inline static const std::string perspective = "perspective";
49 };
50
56 inline static const std::string cameraDistance = "cameraDistance";
57 };
58
65 std::string kernel = Kernel::ellipse;
66
74
82
90
97 int64_t getSizeBytes() const {
98 int64_t accum = 0;
99 accum += int64_t(sizeof(ExtensionKhrGaussianSplatting));
101 int64_t(sizeof(CesiumUtility::ExtensibleObject));
102
103 return accum;
104 }
105};
106} // namespace CesiumGltf
Known values for The color space of the reconstructed color values.
lin_rec709_display
srgb_rec709_display
Known values for The kernel used to generate the Gaussians.
Known values for The projection method for rendering the Gaussians.
Known values for The sorting method for rendering the Gaussians.
Data defining a 3D Gaussian Splat primitive.
std::string projection
std::string sortingMethod
std::string colorSpace
std::string kernel
