CesiumGltf::ExtensionKhrDracoMeshCompression Struct Referencefinal
KHR_draco_mesh_compression glTF Mesh Primitive Extension. More...
#include <CesiumGltf/ExtensionKhrDracoMeshCompression.h>
Inheritance diagram for CesiumGltf::ExtensionKhrDracoMeshCompression:
int32_t bufferView = -1
 The index of the bufferView.
std::unordered_map< std::string, int32_t > attributes
 A dictionary object, where each key corresponds to an attribute and its unique attribute id stored in the compressed geometry.
static constexpr const char * TypeName = "ExtensionKhrDracoMeshCompression"
static constexpr const char * ExtensionName = "KHR_draco_mesh_compression"
Definition at line 16 of file ExtensionKhrDracoMeshCompression.h.
int64_t CesiumGltf::ExtensionKhrDracoMeshCompression::getSizeBytes ( ) const
Definition at line 43 of file ExtensionKhrDracoMeshCompression.h.
◆ attributes
std::unordered_map<std::string, int32_t> CesiumGltf::ExtensionKhrDracoMeshCompression::attributes
Definition at line 35 of file ExtensionKhrDracoMeshCompression.h.
◆ bufferView
int32_t CesiumGltf::ExtensionKhrDracoMeshCompression::bufferView = -1
Definition at line 29 of file ExtensionKhrDracoMeshCompression.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionKhrDracoMeshCompression::ExtensionName = "KHR_draco_mesh_compression"
Definition at line 24 of file ExtensionKhrDracoMeshCompression.h.
const char* CesiumGltf::ExtensionKhrDracoMeshCompression::TypeName = "ExtensionKhrDracoMeshCompression"
Definition at line 21 of file ExtensionKhrDracoMeshCompression.h.
