CesiumGltf::ExtensionKhrBillboard Struct Referencefinal
KHR_billboard glTF Node Extension. More...
#include <CesiumGltf/ExtensionKhrBillboard.h>
Inheritance diagram for CesiumGltf::ExtensionKhrBillboard:
Classes
struct  RotationAxisItems
 Known values for rotationAxis. More...
bool overlay = false
 If true, the billboard is rendered on top of other objects. (Default: false)
std::vector< std::string > rotationAxis = {"X", "Y", "Z"}
 The axes around which the billboard rotates. 'X', 'Y', and/or 'Z'. (Default: ['X', 'Y', 'Z'])
bool scaleWithDistance = false
 If true, the billboard scales with distance from the camera. (Default: false)
std::vector< double > up = {0, 1, 0}
 The up direction of the billboard. Must be defined if viewDirection is parallel to the default up vector. (Default: +Y)
std::vector< double > viewDirection = {0, 0, 1}
 The view direction of the billboard. (Default: +Z)
static constexpr const char * TypeName = "ExtensionKhrBillboard"
static constexpr const char * ExtensionName = "KHR_billboard"
Definition at line 15 of file ExtensionKhrBillboard.h.
int64_t CesiumGltf::ExtensionKhrBillboard::getSizeBytes ( ) const
Definition at line 74 of file ExtensionKhrBillboard.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionKhrBillboard::ExtensionName = "KHR_billboard"
Definition at line 23 of file ExtensionKhrBillboard.h.
◆ overlay
bool CesiumGltf::ExtensionKhrBillboard::overlay = false
Definition at line 43 of file ExtensionKhrBillboard.h.
◆ rotationAxis
std::vector<std::string> CesiumGltf::ExtensionKhrBillboard::rotationAxis = {"X", "Y", "Z"}
Definition at line 49 of file ExtensionKhrBillboard.h.
◆ scaleWithDistance
bool CesiumGltf::ExtensionKhrBillboard::scaleWithDistance = false
Definition at line 55 of file ExtensionKhrBillboard.h.
const char* CesiumGltf::ExtensionKhrBillboard::TypeName = "ExtensionKhrBillboard"
Definition at line 20 of file ExtensionKhrBillboard.h.
◆ up
std::vector<double> CesiumGltf::ExtensionKhrBillboard::up = {0, 1, 0}
Definition at line 61 of file ExtensionKhrBillboard.h.
◆ viewDirection
std::vector<double> CesiumGltf::ExtensionKhrBillboard::viewDirection = {0, 0, 1}
Definition at line 66 of file ExtensionKhrBillboard.h.
