CesiumGltf::ExtensionExtNodeVisibilityVolume Struct Referencefinal
Defines the structure of the extension object that is associated with a KHR_node_visibility object to define a visibility bounding volume. More...
#include <CesiumGltf/ExtensionExtNodeVisibilityVolume.h>
Inheritance diagram for CesiumGltf::ExtensionExtNodeVisibilityVolume:
CesiumGltf::BoundingVolume boundingVolume
 The visibility bounding volume for the node.
static constexpr const char * TypeName = "ExtensionExtNodeVisibilityVolume"
static constexpr const char * ExtensionName = "EXT_node_visibility_volume"
Definition at line 14 of file ExtensionExtNodeVisibilityVolume.h.
int64_t CesiumGltf::ExtensionExtNodeVisibilityVolume::getSizeBytes ( ) const
Definition at line 35 of file ExtensionExtNodeVisibilityVolume.h.
◆ boundingVolume
CesiumGltf::BoundingVolume CesiumGltf::ExtensionExtNodeVisibilityVolume::boundingVolume
Definition at line 27 of file ExtensionExtNodeVisibilityVolume.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtNodeVisibilityVolume::ExtensionName = "EXT_node_visibility_volume"
Definition at line 22 of file ExtensionExtNodeVisibilityVolume.h.
const char* CesiumGltf::ExtensionExtNodeVisibilityVolume::TypeName = "ExtensionExtNodeVisibilityVolume"
Definition at line 19 of file ExtensionExtNodeVisibilityVolume.h.
