CesiumGltf::ExtensionExtMeshFeatures Struct Referencefinal
An object describing feature IDs for a mesh primitive. More...
#include <CesiumGltf/ExtensionExtMeshFeatures.h>
Inheritance diagram for CesiumGltf::ExtensionExtMeshFeatures:
std::vector< CesiumGltf::FeatureId > featureIds
 An array of feature ID sets.
static constexpr const char * TypeName = "ExtensionExtMeshFeatures"
static constexpr const char * ExtensionName = "EXT_mesh_features"
Definition at line 15 of file ExtensionExtMeshFeatures.h.
int64_t CesiumGltf::ExtensionExtMeshFeatures::getSizeBytes ( ) const
Definition at line 36 of file ExtensionExtMeshFeatures.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtMeshFeatures::ExtensionName = "EXT_mesh_features"
Definition at line 23 of file ExtensionExtMeshFeatures.h.
◆ featureIds
std::vector<CesiumGltf::FeatureId> CesiumGltf::ExtensionExtMeshFeatures::featureIds
Definition at line 28 of file ExtensionExtMeshFeatures.h.
const char* CesiumGltf::ExtensionExtMeshFeatures::TypeName = "ExtensionExtMeshFeatures"
Definition at line 20 of file ExtensionExtMeshFeatures.h.
