Extension of KHR_implicit_shapes.shape to represent an implicit ellipsoid region in a glTF model.
More...
#include <CesiumGltf/ExtensionExtImplicitEllipsoidRegion.h>
| double | semiMajorAxisRadius = double() |
| The radius along the semi-major axis of the reference ellipsoid in meters. Corresponds to the radii along the X and Z axes. | |
| double | semiMinorAxisRadius = double() |
| The radius along the semi-minor axis of the reference ellipsoid in meters. Corresponds to the radius along the Y-axis. | |
| double | minHeight = double() |
| The minimum height of the region relative to the ellipsoid's surface, in meters. May be negative. | |
| double | maxHeight = double() |
| The maximum height of the region relative to the ellipsoid's surface, in meters. May be negative. | |
| double | minLatitude = -1.57079632679 |
| The minimum latitude (a.k.a. polar angle) of the region, in radians. Must be in the range [-pi/2, pi/2]. | |
| double | maxLatitude = 1.57079632679 |
| The maximum latitude (a.k.a. polar angle) of the region, in radians. Must be in the range [-pi/2, pi/2]. | |
| double | minLongitude = -3.14159265359 |
| The minimum longitude (a.k.a. azimuthal angle) of the region, in radians. Must be in the range [-pi, pi]. | |
| double | maxLongitude = 3.14159265359 |
| The maximum longitude (a.k.a. azimuthal angle) of the region, in radians. Must be in the range [-pi, pi]. | |
| static constexpr const char * | TypeName = "ExtensionExtImplicitEllipsoidRegion" |
| static constexpr const char * | ExtensionName = "EXT_implicit_ellipsoid_region" |
Definition at line 13 of file ExtensionExtImplicitEllipsoidRegion.h.
Definition at line 77 of file ExtensionExtImplicitEllipsoidRegion.h.
Definition at line 21 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::maxHeight = double() |
Definition at line 45 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::maxLatitude = 1.57079632679 |
Definition at line 57 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::maxLongitude = 3.14159265359 |
Definition at line 69 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::minHeight = double() |
Definition at line 39 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::minLatitude = -1.57079632679 |
Definition at line 51 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::minLongitude = -3.14159265359 |
Definition at line 63 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::semiMajorAxisRadius = double() |
Definition at line 27 of file ExtensionExtImplicitEllipsoidRegion.h.
| double CesiumGltf::ExtensionExtImplicitEllipsoidRegion::semiMinorAxisRadius = double() |
Definition at line 33 of file ExtensionExtImplicitEllipsoidRegion.h.
Definition at line 18 of file ExtensionExtImplicitEllipsoidRegion.h.
