ExtensionExtImplicitEllipsoidRegion.h
8namespace CesiumGltf {
13struct CESIUMGLTF_API ExtensionExtImplicitEllipsoidRegion final
18 static constexpr const char* TypeName = "ExtensionExtImplicitEllipsoidRegion";
21 static constexpr const char* ExtensionName = "EXT_implicit_ellipsoid_region";
22
27 double semiMajorAxisRadius = double();
28
33 double semiMinorAxisRadius = double();
34
39 double minHeight = double();
40
45 double maxHeight = double();
46
51 double minLatitude = -1.57079632679;
52
57 double maxLatitude = 1.57079632679;
58
63 double minLongitude = -3.14159265359;
64
69 double maxLongitude = 3.14159265359;
70
77 int64_t getSizeBytes() const {
78 int64_t accum = 0;
79 accum += int64_t(sizeof(ExtensionExtImplicitEllipsoidRegion));
81 int64_t(sizeof(CesiumUtility::ExtensibleObject));
82
83 return accum;
84 }
85};
86} // namespace CesiumGltf
Extension of KHR_implicit_shapes.shape to represent an implicit ellipsoid region in a glTF model.
double maxLongitude
The maximum longitude (a.k.a. azimuthal angle) of the region, in radians. Must be in the range [-pi,...
double minHeight
The minimum height of the region relative to the ellipsoid's surface, in meters. May be negative.
The radius along the semi-minor axis of the reference ellipsoid in meters. Corresponds to the radius ...
double minLatitude
The minimum latitude (a.k.a. polar angle) of the region, in radians. Must be in the range [-pi/2,...
double minLongitude
The minimum longitude (a.k.a. azimuthal angle) of the region, in radians. Must be in the range [-pi,...
double maxLatitude
The maximum latitude (a.k.a. polar angle) of the region, in radians. Must be in the range [-pi/2,...
The radius along the semi-major axis of the reference ellipsoid in meters. Corresponds to the radii a...
double maxHeight
The maximum height of the region relative to the ellipsoid's surface, in meters. May be negative.
