CesiumGltf::ExtensionExtImplicitCylinderRegion Struct Referencefinal
Extension of KHR_implicit_shapes.shape to represent an implicit cylinder region in a glTF model. More...
#include <CesiumGltf/ExtensionExtImplicitCylinderRegion.h>
Inheritance diagram for CesiumGltf::ExtensionExtImplicitCylinderRegion:
double minRadius = double()
 The inner radius of the cylinder region along the X and Z axes, in meters.
double maxRadius = double()
 The outer radius of the cylinder region along the X and Z axes, in meters.
double height = double()
 The height of the cylinder in meters along the Y-axis, in meters.
double minAngle = -3.14159265359
 The minimum angle of the cylinder region in radians. In other words, this is the angle where the cylinder region starts. Must be in the range [-pi, pi].
double maxAngle = 3.14159265359
 The maximum angle of the cylinder region in radians. In other words, this is the angle where the cylinder region ends. Must be in the range [-pi, pi].
static constexpr const char * TypeName = "ExtensionExtImplicitCylinderRegion"
static constexpr const char * ExtensionName = "EXT_implicit_cylinder_region"
Definition at line 13 of file ExtensionExtImplicitCylinderRegion.h.
int64_t CesiumGltf::ExtensionExtImplicitCylinderRegion::getSizeBytes ( ) const
Definition at line 60 of file ExtensionExtImplicitCylinderRegion.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtImplicitCylinderRegion::ExtensionName = "EXT_implicit_cylinder_region"
Definition at line 21 of file ExtensionExtImplicitCylinderRegion.h.
◆ height
double CesiumGltf::ExtensionExtImplicitCylinderRegion::height = double()
Definition at line 38 of file ExtensionExtImplicitCylinderRegion.h.
◆ maxAngle
double CesiumGltf::ExtensionExtImplicitCylinderRegion::maxAngle = 3.14159265359
Definition at line 52 of file ExtensionExtImplicitCylinderRegion.h.
◆ maxRadius
double CesiumGltf::ExtensionExtImplicitCylinderRegion::maxRadius = double()
Definition at line 33 of file ExtensionExtImplicitCylinderRegion.h.
◆ minAngle
double CesiumGltf::ExtensionExtImplicitCylinderRegion::minAngle = -3.14159265359
Definition at line 45 of file ExtensionExtImplicitCylinderRegion.h.
◆ minRadius
double CesiumGltf::ExtensionExtImplicitCylinderRegion::minRadius = double()
Definition at line 27 of file ExtensionExtImplicitCylinderRegion.h.
const char* CesiumGltf::ExtensionExtImplicitCylinderRegion::TypeName = "ExtensionExtImplicitCylinderRegion"
Definition at line 18 of file ExtensionExtImplicitCylinderRegion.h.
