ExtensionExtImplicitCylinderRegion.h
8namespace CesiumGltf {
13struct CESIUMGLTF_API ExtensionExtImplicitCylinderRegion final
18 static constexpr const char* TypeName = "ExtensionExtImplicitCylinderRegion";
21 static constexpr const char* ExtensionName = "EXT_implicit_cylinder_region";
22
27 double minRadius = double();
28
33 double maxRadius = double();
34
38 double height = double();
39
45 double minAngle = -3.14159265359;
46
52 double maxAngle = 3.14159265359;
53
60 int64_t getSizeBytes() const {
61 int64_t accum = 0;
62 accum += int64_t(sizeof(ExtensionExtImplicitCylinderRegion));
64 int64_t(sizeof(CesiumUtility::ExtensibleObject));
65
66 return accum;
67 }
68};
69} // namespace CesiumGltf
Extension of KHR_implicit_shapes.shape to represent an implicit cylinder region in a glTF model.
double minRadius
The inner radius of the cylinder region along the X and Z axes, in meters.
double minAngle
The minimum angle of the cylinder region in radians. In other words, this is the angle where the cyli...
double maxRadius
The outer radius of the cylinder region along the X and Z axes, in meters.
double maxAngle
The maximum angle of the cylinder region in radians. In other words, this is the angle where the cyli...
double height
The height of the cylinder in meters along the Y-axis, in meters.
