CesiumGltf::ExtensionExtGeospatialCrsWkid Struct Referencefinal
This extension declares the Coordinate Reference System (CRS) in which a glTF 2.1 asset was authored. The CRS is provided as a Well-Known ID (WKID), commonly an EPSG code. More...
#include <CesiumGltf/ExtensionExtGeospatialCrsWkid.h>
Inheritance diagram for CesiumGltf::ExtensionExtGeospatialCrsWkid:
std::string authority
 The organization that defines and manages a specific CRS identifier.
int64_t wkid = int64_t()
 An integer that identifies the CRS.
std::optional< int64_t > vcsWkid
 An integer that identifies the vertical CRS if wkid identifies a horizontal CRS.
std::optional< std::string > epoch
 An epoch for coordinates that are referenced to a dynamic CRS such as WGS 84. Expressed as a decimal year (e.g. '2019.81').
static constexpr const char * TypeName = "ExtensionExtGeospatialCrsWkid"
static constexpr const char * ExtensionName = "EXT_geospatial_crs_wkid"
Definition at line 18 of file ExtensionExtGeospatialCrsWkid.h.
int64_t CesiumGltf::ExtensionExtGeospatialCrsWkid::getSizeBytes ( ) const
Definition at line 56 of file ExtensionExtGeospatialCrsWkid.h.
◆ authority
std::string CesiumGltf::ExtensionExtGeospatialCrsWkid::authority
Definition at line 31 of file ExtensionExtGeospatialCrsWkid.h.
◆ epoch
std::optional<std::string> CesiumGltf::ExtensionExtGeospatialCrsWkid::epoch
Definition at line 48 of file ExtensionExtGeospatialCrsWkid.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtGeospatialCrsWkid::ExtensionName = "EXT_geospatial_crs_wkid"
Definition at line 26 of file ExtensionExtGeospatialCrsWkid.h.
const char* CesiumGltf::ExtensionExtGeospatialCrsWkid::TypeName = "ExtensionExtGeospatialCrsWkid"
Definition at line 23 of file ExtensionExtGeospatialCrsWkid.h.
◆ vcsWkid
std::optional<int64_t> CesiumGltf::ExtensionExtGeospatialCrsWkid::vcsWkid
Definition at line 42 of file ExtensionExtGeospatialCrsWkid.h.
◆ wkid
int64_t CesiumGltf::ExtensionExtGeospatialCrsWkid::wkid = int64_t()
Definition at line 36 of file ExtensionExtGeospatialCrsWkid.h.
