23 static constexpr const char*
TypeName =
"ExtensionExtGeospatialCrsWkid";
48 std::optional<std::string>
epoch;
61 accum += int64_t(this->authority.capacity() *
sizeof(
char));
63 accum += int64_t(this->epoch->capacity() *
sizeof(
char));
This extension declares the Coordinate Reference System (CRS) in which a glTF 2.1 asset was authored....
std::optional< std::string > epoch
An epoch for coordinates that are referenced to a dynamic CRS such as WGS 84. Expressed as a decimal ...
std::string authority
The organization that defines and manages a specific CRS identifier.
int64_t wkid
An integer that identifies the CRS.
int64_t getSizeBytes() const
std::optional< int64_t > vcsWkid
An integer that identifies the vertical CRS if wkid identifies a horizontal CRS.
