CesiumGltf::ExtensionExtGeospatialCrs Struct Referencefinal
This extension declares the Coordinate Reference System (CRS) in which a glTF 2.1 asset was authored. More...
#include <CesiumGltf/ExtensionExtGeospatialCrs.h>
Inheritance diagram for CesiumGltf::ExtensionExtGeospatialCrs:
std::string format
 The coordinate reference system format, whose value must be defined by additional extensions.
static constexpr const char * TypeName = "ExtensionExtGeospatialCrs"
static constexpr const char * ExtensionName = "EXT_geospatial_crs"
Definition at line 15 of file ExtensionExtGeospatialCrs.h.
int64_t CesiumGltf::ExtensionExtGeospatialCrs::getSizeBytes ( ) const
Definition at line 37 of file ExtensionExtGeospatialCrs.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtGeospatialCrs::ExtensionName = "EXT_geospatial_crs"
Definition at line 23 of file ExtensionExtGeospatialCrs.h.
◆ format
std::string CesiumGltf::ExtensionExtGeospatialCrs::format
Definition at line 29 of file ExtensionExtGeospatialCrs.h.
const char* CesiumGltf::ExtensionExtGeospatialCrs::TypeName = "ExtensionExtGeospatialCrs"
Definition at line 20 of file ExtensionExtGeospatialCrs.h.
