ExtensionExtGeospatialCrs.h
8#include <string>
9
10namespace CesiumGltf {
15struct CESIUMGLTF_API ExtensionExtGeospatialCrs final
20 static constexpr const char* TypeName = "ExtensionExtGeospatialCrs";
23 static constexpr const char* ExtensionName = "EXT_geospatial_crs";
24
29 std::string format;
30
37 int64_t getSizeBytes() const {
38 int64_t accum = 0;
39 accum += int64_t(sizeof(ExtensionExtGeospatialCrs));
41 int64_t(sizeof(CesiumUtility::ExtensibleObject));
42 accum += int64_t(this->format.capacity() * sizeof(char));
43 return accum;
44 }
45};
46} // namespace CesiumGltf
This extension declares the Coordinate Reference System (CRS) in which a glTF 2.1 asset was authored.
std::string format
The coordinate reference system format, whose value must be defined by additional extensions.
