CesiumGltf::ExtensionBufferExtMeshoptCompression Struct Referencefinal
Compressed data for bufferView. More...
#include <CesiumGltf/ExtensionBufferExtMeshoptCompression.h>
Inheritance diagram for CesiumGltf::ExtensionBufferExtMeshoptCompression:
bool fallback = false
 Set to true to indicate that the buffer is only referenced by bufferViews that have EXT_meshopt_compression extension and as such doesn't need to be loaded.
static constexpr const char * ExtensionName = "EXT_meshopt_compression"
Definition at line 12 of file ExtensionBufferExtMeshoptCompression.h.
int64_t CesiumGltf::ExtensionBufferExtMeshoptCompression::getSizeBytes ( ) const
Definition at line 36 of file ExtensionBufferExtMeshoptCompression.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionBufferExtMeshoptCompression::ExtensionName = "EXT_meshopt_compression"
Definition at line 21 of file ExtensionBufferExtMeshoptCompression.h.
◆ fallback
bool CesiumGltf::ExtensionBufferExtMeshoptCompression::fallback = false
Definition at line 28 of file ExtensionBufferExtMeshoptCompression.h.
const char* CesiumGltf::ExtensionBufferExtMeshoptCompression::TypeName
Initial value:
"ExtensionBufferExtMeshoptCompression"
Definition at line 17 of file ExtensionBufferExtMeshoptCompression.h.
