ExtensionBufferExtMeshoptCompression.h
8namespace CesiumGltf {
12struct CESIUMGLTF_API ExtensionBufferExtMeshoptCompression final
17 static constexpr const char* TypeName =
18 "ExtensionBufferExtMeshoptCompression";
21 static constexpr const char* ExtensionName = "EXT_meshopt_compression";
22
28 bool fallback = false;
29
36 int64_t getSizeBytes() const {
37 int64_t accum = 0;
38 accum += int64_t(sizeof(ExtensionBufferExtMeshoptCompression));
40 int64_t(sizeof(CesiumUtility::ExtensibleObject));
41
42 return accum;
43 }
44};
45} // namespace CesiumGltf
bool fallback
Set to true to indicate that the buffer is only referenced by bufferViews that have EXT_meshopt_compr...
