An object describing tile, content, and child subtree availability, attributes, and properties. More...
#include <CesiumGltf/Extension3dTilesSubtree.h>
| CesiumGltf::Availability | tileAvailability |
| The availability of tiles in the subtree. | |
| std::optional< CesiumGltf::Availability > | contentAvailability |
| The availability of contents in the subtree. | |
| CesiumGltf::Availability | childSubtreeAvailability |
| The availability of child subtrees. | |
| std::unordered_map< std::string, int32_t > | tileAttributes |
| A dictionary mapping tile attribute semantics to accessor indices. | |
| std::unordered_map< std::string, int32_t > | contentAttributes |
| A dictionary mapping content attribute semantics to accessor indices. | |
| int32_t | tileProperties = -1 |
| Index of the property table containing tile properties. | |
| int32_t | contentProperties = -1 |
| Index of the property table containing content properties. | |
| static constexpr const char * | TypeName = "Extension3dTilesSubtree" |
| static constexpr const char * | ExtensionName = "3DTILES_subtree" |
Definition at line 19 of file Extension3dTilesSubtree.h.
Definition at line 113 of file Extension3dTilesSubtree.h.
| CesiumGltf::Availability CesiumGltf::Extension3dTilesSubtree::childSubtreeAvailability |
The availability of children subtrees. The availability bitstream is a 1D boolean array where subtrees are ordered by their Morton index in the level of the tree immediately below the bottom row of the subtree. A child subtree's availability is determined by a single bit, 1 meaning a subtree exists at that spatial index, and 0 meaning it does not. The number of elements in the array is N^subtreeLevels where N is 4 for subdivision scheme QUADTREE and 8 for OCTREE. Availability may be stored in a buffer view or as a constant value that applies to all child subtrees. If availability is 0 for all child subtrees, then the tileset does not subdivide further.
Definition at line 64 of file Extension3dTilesSubtree.h.
| std::unordered_map<std::string, int32_t> CesiumGltf::Extension3dTilesSubtree::contentAttributes |
A plain JSON object, where each key corresponds to a content attribute semantic and each value is the index of the accessor containing attribute's data. Attribute values only exists for available contents and are ordered by increasing tile index.
Definition at line 85 of file Extension3dTilesSubtree.h.
| std::optional<CesiumGltf::Availability> CesiumGltf::Extension3dTilesSubtree::contentAvailability |
Definition at line 48 of file Extension3dTilesSubtree.h.
| int32_t CesiumGltf::Extension3dTilesSubtree::contentProperties = -1 |
Content properties only exist for available contents and are tightly packed by increasing tile index. To access individual content properties, implementations may create a mapping from tile indices to content property indices.
Definition at line 105 of file Extension3dTilesSubtree.h.
Definition at line 27 of file Extension3dTilesSubtree.h.
| std::unordered_map<std::string, int32_t> CesiumGltf::Extension3dTilesSubtree::tileAttributes |
A plain JSON object, where each key corresponds to a tile attribute semantic and each value is the index of the accessor containing attribute's data. Attribute values only exists for available tiles and are ordered by increasing tile index.
Definition at line 74 of file Extension3dTilesSubtree.h.
| CesiumGltf::Availability CesiumGltf::Extension3dTilesSubtree::tileAvailability |
The availability bitstream is a 1D boolean array where tiles are ordered by their level in the subtree and Morton index within that level. A tile's availability is determined by a single bit, 1 meaning a tile exists at that spatial index, and 0 meaning it does not. The number of elements in the array is (N^subtreeLevels - 1)/(N - 1) where N is 4 for subdivision scheme QUADTREE and 8 for OCTREE. Availability may be stored in a buffer view or as a constant value that applies to all tiles. If a non-root tile's availability is 1 its parent tile's availability must also be 1. tileAvailability.constant: 0 is disallowed, as subtrees must have at least one tile.
Definition at line 43 of file Extension3dTilesSubtree.h.
| int32_t CesiumGltf::Extension3dTilesSubtree::tileProperties = -1 |
Tile properties only exist for available tiles and are tightly packed by increasing tile index. To access individual tile properties, implementations may create a mapping from tile indices to tile property indices.
Definition at line 95 of file Extension3dTilesSubtree.h.
Definition at line 24 of file Extension3dTilesSubtree.h.
