3DTILES_shape_s2 More...
#include <CesiumGltf/Extension3dTilesShapeS2.h>
| std::string | token |
| A hexadecimal representation of the S2CellId. Tokens shall be lower-case, shall not contain whitespace and shall have trailing zeros stripped. | |
| double | minimumHeight = double() |
| The minimum height of the tile, specified in meters above (or below) the WGS84 ellipsoid. | |
| double | maximumHeight = double() |
| The maximum height of the tile, specified in meters above (or below) the WGS84 ellipsoid. | |
| static constexpr const char * | TypeName = "Extension3dTilesShapeS2" |
| static constexpr const char * | ExtensionName = "3DTILES_shape_s2" |
3DTILES_shape_s2
Definition at line 14 of file Extension3dTilesShapeS2.h.
Definition at line 49 of file Extension3dTilesShapeS2.h.
Definition at line 22 of file Extension3dTilesShapeS2.h.
| double CesiumGltf::Extension3dTilesShapeS2::maximumHeight = double() |
Definition at line 41 of file Extension3dTilesShapeS2.h.
| double CesiumGltf::Extension3dTilesShapeS2::minimumHeight = double() |
Definition at line 35 of file Extension3dTilesShapeS2.h.
| std::string CesiumGltf::Extension3dTilesShapeS2::token |
Definition at line 29 of file Extension3dTilesShapeS2.h.
Definition at line 19 of file Extension3dTilesShapeS2.h.
