Extension3dTilesShapeS2.h
8#include <string>
9
10namespace CesiumGltf {
14struct CESIUMGLTF_API Extension3dTilesShapeS2 final
19 static constexpr const char* TypeName = "Extension3dTilesShapeS2";
22 static constexpr const char* ExtensionName = "3DTILES_shape_s2";
23
29 std::string token;
30
35 double minimumHeight = double();
36
41 double maximumHeight = double();
42
49 int64_t getSizeBytes() const {
50 int64_t accum = 0;
51 accum += int64_t(sizeof(Extension3dTilesShapeS2));
53 int64_t(sizeof(CesiumUtility::ExtensibleObject));
54 accum += int64_t(this->token.capacity() * sizeof(char));
55 return accum;
56 }
57};
58} // namespace CesiumGltf
The minimum height of the tile, specified in meters above (or below) the WGS84 ellipsoid.
std::string token
A hexadecimal representation of the S2CellId. Tokens shall be lower-case, shall not contain whitespac...
The maximum height of the tile, specified in meters above (or below) the WGS84 ellipsoid.
