3DTILES_shape_ellipsoid_region More...
#include <CesiumGltf/Extension3dTilesShapeEllipsoidRegion.h>
| double | minimumHeight = double() |
| The minimum height of the region relative to the ellipsoid's surface, in meters. May be negative. | |
| double | maximumHeight = double() |
| The maximum height of the region relative to the ellipsoid's surface, in meters. May be negative. | |
| double | minimumLatitude = -1.57079632679 |
| The minimum latitude of the region, in radians. Must be in the range [-pi/2, pi/2]. | |
| double | maximumLatitude = 1.57079632679 |
| The maximum latitude of the region, in radians. Must be in the range [-pi/2, pi/2]. | |
| double | minimumLongitude = -3.14159265359 |
| The minimum longitude of the region, in radians. Minimum and maximum longitude must evaluate to (0 <= abs(maximumLongitude - minimumLongitude) <= 2 * pi). | |
| double | maximumLongitude = 3.14159265359 |
| The maximum longitude of the region, in radians. Minimum and maximum longitude must evaluate to (0 <= abs(maximumLongitude - minimumLongitude) <= 2 * pi). | |
| static constexpr const char * | ExtensionName = "3DTILES_shape_ellipsoid_region" |
Definition at line 12 of file Extension3dTilesShapeEllipsoidRegion.h.
Definition at line 67 of file Extension3dTilesShapeEllipsoidRegion.h.
Definition at line 21 of file Extension3dTilesShapeEllipsoidRegion.h.
| double CesiumGltf::Extension3dTilesShapeEllipsoidRegion::maximumHeight = double() |
Definition at line 33 of file Extension3dTilesShapeEllipsoidRegion.h.
| double CesiumGltf::Extension3dTilesShapeEllipsoidRegion::maximumLatitude = 1.57079632679 |
Definition at line 45 of file Extension3dTilesShapeEllipsoidRegion.h.
| double CesiumGltf::Extension3dTilesShapeEllipsoidRegion::maximumLongitude = 3.14159265359 |
Definition at line 59 of file Extension3dTilesShapeEllipsoidRegion.h.
| double CesiumGltf::Extension3dTilesShapeEllipsoidRegion::minimumHeight = double() |
Definition at line 27 of file Extension3dTilesShapeEllipsoidRegion.h.
| double CesiumGltf::Extension3dTilesShapeEllipsoidRegion::minimumLatitude = -1.57079632679 |
Definition at line 39 of file Extension3dTilesShapeEllipsoidRegion.h.
| double CesiumGltf::Extension3dTilesShapeEllipsoidRegion::minimumLongitude = -3.14159265359 |
Definition at line 52 of file Extension3dTilesShapeEllipsoidRegion.h.
Definition at line 17 of file Extension3dTilesShapeEllipsoidRegion.h.
