18 "Extension3dTilesShapeEllipsoidRegion";
21 static constexpr const char*
ExtensionName =
"3DTILES_shape_ellipsoid_region";
double maximumHeight
The maximum height of the region relative to the ellipsoid's surface, in meters. May be negative.
double minimumHeight
The minimum height of the region relative to the ellipsoid's surface, in meters. May be negative.
double maximumLongitude
The maximum longitude of the region, in radians. Minimum and maximum longitude must evaluate to (0 <=...
double maximumLatitude
The maximum latitude of the region, in radians. Must be in the range [-pi/2, pi/2].
double minimumLatitude
The minimum latitude of the region, in radians. Must be in the range [-pi/2, pi/2].
double minimumLongitude
The minimum longitude of the region, in radians. Minimum and maximum longitude must evaluate to (0 <=...
int64_t getSizeBytes() const
