3DTILES_shape_cylinder_region More...
#include <CesiumGltf/Extension3dTilesShapeCylinderRegion.h>
| double | minimumRadius = double() |
| The inner radius of the cylinder region along the X and Z axes, in meters. | |
| double | maximumRadius = double() |
| The outer radius of the cylinder region along the X and Z axes, in meters. | |
| double | height = double() |
| The height of the cylinder along the Y-axis, in meters. | |
| double | minimumAngle = -3.14159265359 |
| The minimum angle of the cylinder region in radians. In other words, this is the angle where the cylinder region starts. Together with maximumAngle this must satisfy (0 <= abs(maximumAngle - minimumAngle) <= 2. | |
| double | maximumAngle = 3.14159265359 |
| The maximum angle of the cylinder region in radians. In other words, this is the angle where the cylinder region ends. Together with maximumAngle this must satisfy (0 <= abs(maximumAngle - minimumAngle) <= 2. | |
| static constexpr const char * | TypeName = "Extension3dTilesShapeCylinderRegion" |
| static constexpr const char * | ExtensionName = "3DTILES_shape_cylinder_region" |
Definition at line 12 of file Extension3dTilesShapeCylinderRegion.h.
Definition at line 61 of file Extension3dTilesShapeCylinderRegion.h.
Definition at line 20 of file Extension3dTilesShapeCylinderRegion.h.
| double CesiumGltf::Extension3dTilesShapeCylinderRegion::height = double() |
Definition at line 37 of file Extension3dTilesShapeCylinderRegion.h.
| double CesiumGltf::Extension3dTilesShapeCylinderRegion::maximumAngle = 3.14159265359 |
Definition at line 53 of file Extension3dTilesShapeCylinderRegion.h.
| double CesiumGltf::Extension3dTilesShapeCylinderRegion::maximumRadius = double() |
Definition at line 32 of file Extension3dTilesShapeCylinderRegion.h.
| double CesiumGltf::Extension3dTilesShapeCylinderRegion::minimumAngle = -3.14159265359 |
Definition at line 45 of file Extension3dTilesShapeCylinderRegion.h.
| double CesiumGltf::Extension3dTilesShapeCylinderRegion::minimumRadius = double() |
Definition at line 26 of file Extension3dTilesShapeCylinderRegion.h.
Definition at line 17 of file Extension3dTilesShapeCylinderRegion.h.
