Extension3dTilesShapeCylinderRegion.h
8namespace CesiumGltf {
12struct CESIUMGLTF_API Extension3dTilesShapeCylinderRegion final
17 static constexpr const char* TypeName = "Extension3dTilesShapeCylinderRegion";
20 static constexpr const char* ExtensionName = "3DTILES_shape_cylinder_region";
21
26 double minimumRadius = double();
27
32 double maximumRadius = double();
33
37 double height = double();
38
45 double minimumAngle = -3.14159265359;
46
53 double maximumAngle = 3.14159265359;
54
61 int64_t getSizeBytes() const {
62 int64_t accum = 0;
63 accum += int64_t(sizeof(Extension3dTilesShapeCylinderRegion));
65 int64_t(sizeof(CesiumUtility::ExtensibleObject));
66
67 return accum;
68 }
69};
70} // namespace CesiumGltf
The outer radius of the cylinder region along the X and Z axes, in meters.
The inner radius of the cylinder region along the X and Z axes, in meters.
double minimumAngle
The minimum angle of the cylinder region in radians. In other words, this is the angle where the cyli...
double maximumAngle
The maximum angle of the cylinder region in radians. In other words, this is the angle where the cyli...
double height
The height of the cylinder along the Y-axis, in meters.
