Cylinder.h
8namespace CesiumGltf {
16struct CESIUMGLTF_API Cylinder final : public CesiumUtility::ExtensibleObject {
20 static constexpr const char* TypeName = "Cylinder";
21
25 double height = 2;
26
31 double radiusBottom = 0.5;
32
36 double radiusTop = 0.5;
37
44 int64_t getSizeBytes() const {
45 int64_t accum = 0;
46 accum += int64_t(sizeof(Cylinder));
48 int64_t(sizeof(CesiumUtility::ExtensibleObject));
49
50 return accum;
51 }
52};
53} // namespace CesiumGltf
A cylinder, centered at the origin in local space with potentially different radii at each end,...
Definition Cylinder.h:16
double radiusBottom
The radius of the bottom of the cylinder (the disc located along -Y.)
Definition Cylinder.h:31
Definition Cylinder.h:20
double height
The height of the cylinder, centered along the Y axis.
Definition Cylinder.h:25
double radiusTop
The radius of the top of the cylinder (the disc located along +Y.)
Definition Cylinder.h:36
Definition Cylinder.h:44
