CameraPerspective.h
8#include <optional>
9
10namespace CesiumGltf {
15struct CESIUMGLTF_API CameraPerspective final
20 static constexpr const char* TypeName = "CameraPerspective";
21
28 std::optional<double> aspectRatio;
29
34 double yfov = double();
35
43 std::optional<double> zfar;
44
48 double znear = double();
49
56 int64_t getSizeBytes() const {
57 int64_t accum = 0;
58 accum += int64_t(sizeof(CameraPerspective));
60 int64_t(sizeof(CesiumUtility::ExtensibleObject));
61
62 return accum;
63 }
64};
65} // namespace CesiumGltf
A perspective camera containing properties to create a perspective projection matrix.
double znear
The floating-point distance to the near clipping plane.
std::optional< double > aspectRatio
The floating-point aspect ratio of the field of view.
double yfov
The floating-point vertical field of view in radians. This value SHOULD be less than π.
std::optional< double > zfar
The floating-point distance to the far clipping plane.
