CameraOrthographic.h
8namespace CesiumGltf {
13struct CESIUMGLTF_API CameraOrthographic final
18 static constexpr const char* TypeName = "CameraOrthographic";
19
24 double xmag = double();
25
30 double ymag = double();
31
36 double zfar = double();
37
41 double znear = double();
42
49 int64_t getSizeBytes() const {
50 int64_t accum = 0;
51 accum += int64_t(sizeof(CameraOrthographic));
53 int64_t(sizeof(CesiumUtility::ExtensibleObject));
54
55 return accum;
56 }
57};
58} // namespace CesiumGltf
An orthographic camera containing properties to create an orthographic projection matrix.
double xmag
The floating-point horizontal magnification of the view. This value MUST NOT be equal to zero....
double zfar
The floating-point distance to the far clipping plane. This value MUST NOT be equal to zero....
double ymag
The floating-point vertical magnification of the view. This value MUST NOT be equal to zero....
double znear
The floating-point distance to the near clipping plane.
